Help with IDing rear diff
77 K10, trying to ID my rear diff. I can't find a plate on it anywhere and I want to make sure I can get a new gasket so I can change the fluid. Anybody recognize this? I'm pretty new to trucks, and don't know a whole lot yet. I Googled 12 bolt GM rear ends, but everything I've found says they weren't on a 77 K10
https://imgur.com/gallery/kFvn96T |
Re: Help with IDing rear diff
12 bolt truck rear diff .
skip the gasket and get a tube of RIGHT STUFF gasket maker and use it to make a decent bead . or do a gasket and some rtv on both sides . the last few diff cover gaskets i did 100% dry and clean are ozzing fluid . so i need to drain and reseal dam it . going with option one i posted above like i should have from the start . |
I ended up pulling off the cover. It looks like it maybe has limited slip or something but I'm not positive what it is exactly. Also there's a tiny little gear deal with some broken teeth and a shaft that's all stripped. Anybody know?
https://imgur.com/gallery/UyAfXzt |
Eaton G80 Gov Loc and it's on the way out.
Just my luck. Do you think this is something worth trying to repair? Or should I replace the entire carrier? I'm thinking about throwing the cover back on, filling it with fluid, and forgetting about it untill I can buy myself a new one for Christmas |
They have a bad reputation for doing just exactly what this one did and then dropping the weights into the ring and pinion.
Right now you don't necessarily need ring and pinion gears. If you're careful and lucky it'll last til you can replace it. If you don't luck out those weights will get into the gears and make a larger mess. Get a Limited Slip Diff. It'll behave and it won't explode. |
I just read that those weights can be removed and basically turn it into an open diff, so that's probably what I'll do to buy myself some time. What are your thoughts on the Eaton TrueTrac? |
The Yukon clutch pak LSD will react faster and more consistently. And they are less expensive.
The 12bolt truck axle is 8.875" ring gear and the axles are 30 spline.
The 12bolt car axles could have several spline counts but the 12bolt truck used 30 spline. There are three different carrier sizes. You'll need to know what the ring & pinion ratio is...
I have a Truetrac in the front 10 bolt on my 81 and its been flawless no issues. The only problem is for the 12 bolt (and 10 bolt), you need the 3.73 and up carrier to use.
As I noted a couple posts ago there are three carrier sizes. Eaton doesn't cover the 2.73:1 carrier and I don't see any others listed for that size either. If you have that gearset you're changing gear ratio or not putting in an LSD. You do have a choice of using an Auburn or Yukon with your rear end... not just Eaton. I've run Auburns in 3.75" Chrysler rears under a 69 Fury and two 69 Dodge Polaras. All three had built B383 engines and A833 transmissions. I was not gentle with any of them. The Auburn LSDs cured my one wheel peels and hooked up both sides near instantly under some challenging conditions and they did it without exploding. I turned propshafts into pretzels and broke ears off yokes but the rears held up just fine. https://www.justdifferentials.com/category-s/2285.htm |
gear ratio is stamper on ring gear .
41-10 or 41-9 are a few examples . big # divided by little # = ratio . and also look in to detroit true trac . helical cut all gear posi and requires no additive in fluid . |
Usually the gear ratio or at least the tooth count and part number is stamped on the side of the ring gear.
Just spin it around til the stamp is showing. |
Ring gear stamping https://imgur.com/gallery/ik9wO7n |
ring gear looks like 1978 made .
as to ratio that got eaten up when they cut the gear . . looks like your counting . but if i was to make a crazy shot at it from your pic and guess maybe 41/11 = 3.73 and they were common . |
What do I go about counting? How many teeth on the ring gear? Or should I just plan on replacing ring and pinion as well due to those chunks missing? |
You probably get to install bearings and seals in the end of the axle tubes as well. I'd look into what it would cost for a used 10 bolt or 12 bolt with the same ratio and a warranty. Pull the cover and look it over before you take it home. |
Part of the reason I bought this truck was to be able to wrench on it, and learn things, and I just think it’s cool to know every inch of it like the back of my hand. I think I’m going to wait and rebuild it completely myself in a few months. I’ll orobably completely redo everything except for the axles themselves |
Thank you |
