WTB: Blazer fuel filler neck
I need a 69-72 K5 filler neck.
Long shot I know but seeing no replacements available. It can have holes, dented etc.. I'm just using it for a pattern anyway unless somebody has a decent one. Thanks in advance! |
Re: WTB: Blazer fuel filler neck
I have a 72 that needs a lot of TLC 15 plus shipping.
Just an fyi 69-70 is 2 pieces and has a different mounting flange 71 is also 2 pieces and has a round mounting flange like a 72 72 is all 1 piece |
I did know the difference but thought I'd throw a wide net.
Really good info though It's going to a 72 SB pickup with a '91 K5 EFI tank mounted out back with neck going to RH side. I'll send you a PM in a minute...and thanks for reply |
The one in the link above is the better of the 2
What year are you working on, 69-70 2 pieces, 71-72 1 piece.
Neither of them to be honest. Was just looking to see whatever I could find.
I put a LS3/TR6060 into a 72 short bed with a 91 EFI Blazer 31g fuel tank. The tank filler goes to the right side vs stock LH Blazer however if you flop the the filler neck from LH to RH side everything reverses and lines up. Add reducing fill hose and it's good to go. 1rippen6 had what I needed so Im covered. :thumbs: |
3 Attachment(s)
Here is what I did hope it helps, let me know if you need better measurements.
I went to the edge of the hole.
