Barn door latches
Does anyone know of a replacement / alternate part for the striker for the left hand barn door of a 1990 suburban? I only need that one striker and can't find anyone parting a burb willing to sell such a small item . I suppose I could get one welded up but was trying to avoid that route. Thanks
Re: Barn door latches
pretty sure the vans use the exact same ones. should be easy to find at the junkyard.
Thanks ,that's just the kind of info I was looking for. I'll check it out
Anyone confirm this yet? I'm needing some too and I'm guessing the van would have to be a similar vintage?
Have you checked with the dealer? They might suprise you.
No, just got it so I'm just making a list and info searching. Hadn't thought about the dealer, but I'll give them a try
I just looked thru my stuff, and confirmed the van one is identical. I have a van and a sub here to compare.
Thank you, that may help with the search. Dealer said NLA to everything I asked about
I was in an older junkyard today and confirmed the Chevy vans have an identical latch loop.older 70s are a little different but look like they may also work . Thanks for the tip.
the actual bottom latch in the doors are the same also between the van and sub rear doors.
