WTB: Front rubber cushion - 283 horseshoe mount
I have the metal bracket for the front horseshoe mount on a 283 on my 62, but need the rubber cushion and bolt. I'm going from a 235 to a 283 - would the front rubber cushion possibly be the same for both engines? Let me know if you have one or know if they are the same.
Thanks Bob |
Re: WTB: Front rubber cushion - 283 horseshoe mount
Yes - I have the metal U shaped bracket, just need the rubber bushing / cushion. It might be the same as the one used on the 235 in 62, but I have not been able to confirm.
Thanks Bob |
You could get one maybe at Aspen C10 Parts in Arizona - https://www.aspenautoaz.com/60-66-ch...uck-parts.html
If it's in bad condition you could have it re-vulcanized. I thought Jim Carter would have them but they arent listed - http://www.oldchevytrucks.com/cart/i...0motor%20mount Probably be easier to change to the next series mounts. |
