V8 np435
Anyone running this combo in their truck? Its in the v8 position and the high hump doesn’t work, looks like I need to use the I6 location for the engine mounts and move the trans crossmember back accordingly.
Not a common combination, the trans was previously behind a GMC 305 V6. Thanks, Jon |
Re: V8 np435
I have the Big block and NP435.
Motor mount location shown here. https://cache.nebula.phx3.secureserv...e-fdb51164a9df |
Re: V8 np435
Re: V8 np435
Yes,High Hump With rectangular hole.
Here is a pic before I install the shift boot. https://cache.nebula.phx3.secureserv...7-f0a2f1e5f9ca https://cache.nebula.phx3.secureserv...9-c72f1791643a |
Re: V8 np435
Mine is further back in the flat portion of the cover. I’m betting I’m going to need to move the engine. Thank you for the pics!
Re: V8 np435
Engines now in the I6 location(V8 stands) and the high hump still won’t work, this engine and trans was in my C3500 but had been relocated in the frame after the V6 wore out, I’m wanting it in the right spot...hopefully someone on here has a V8/NP435 to confirm and tell me if I need the high hump like Astro’s
Re: V8 np435
Post some pics of your trans and bell housing, Engine mounts.
Re: V8 np435
3 Attachment(s)
Here are pics like you requested. :gmc2:
I figured I should respond in your thread and not the other one so that if someone else has an issue they can find the answer easier. My T-Hump looks just like the one that the guy with the big block posted. Looks like it's in the front holes. If you need pics of the transmission crossmember let me know and I can get those, too. Maybe you need a different bellhousing or something. I can get any pics you need! |
Re: V8 np435
Thank you! I’ll move it back to the front holes and track down a square hole cover like the one you guys have. My trans was bolted to the crossmember in the front position. I appreciate the help!
Re: V8 np435
Re: V8 np435
Re: V8 np435
Here are the parts I used as listed on Rock Auto. Not sure how to post a link to just the one part, but you can search the part number in the brackets and it'll come up. Flywheel - PERFECTION CLUTCH 506504 {#3991469} - $79.99 Clutch Kit - PERFECTION CLUTCH MU90911 {#90681} - $65.79 |
Re: V8 np435
Re: V8 np435
I would not waist time on a NP435. The Sm 465 is a much better trans.
George |
Re: V8 np435
Re: V8 np435
Re: V8 np435
Re: V8 np435
Thanks again for your help/info! |
Re: V8 np435
