Starting Engine On Frame?
Hey Guys Just Looking For Some Tips and Advice To Start My Engine On The Frame. Have Everything Plumbed. Radiators Hooked Up. + Battery Wire To The Starter
Just Not Sure About The Wiring. Was Going To Use The Keyed Ignition To Turn It Over.. Its An HEI Distributor Posted via Mobile Device |
Re: Starting Engine On Frame?
I'm not sure what you mean. The engine should be on the frame.
Make sure its not in gear. 12v to HEI, jump terminals on starter with a screwdriver or a switch.
I would do like Mike C says and jumper 12v to the HEI and use a remote start button like this:
https://www.amazon.com/Sunpro-CP7853.../dp/B0009XQUKW |
1. Positive side of the Battery to Starter 2. Negative side of the Battery to the Block 3. Remote start button to the Positive side of the Battery and to the "S" terminal on the starter solenoid. 4. Wire from Positive side of the Battery to BAT terminal on HEI (have an alligator clip on the battery end so you can unhook it easily to kill the engine) 5. Pour a little gas in carb if fuel system is not connected 6. Oil Pressure gauge hooked up or you will coat everything around you with oil 7. You may have to close the choke to get it to start. LockDoc |
Thank You Guys
Good luck. Tell us how it went.
Now we don't want you to post a pic of your chassis driving away by itself :lol:
You didn't mention the transmission. Don't forget to fill it with oil too.
Make sure you jack the rear wheels up in case. I just went through this with the 68. If it's not hooked up to the rear end it want matter. I had the drive shaft in. I hooked it all up just like it should be.
Last night.:chevy: https://www.youtube.com/watch?v=TviYONUW5Ag |
