WTB 1967 4 Jet Throttle Linkage
Not sure if this is a universal piece or specific to the 4 jet. Need a good one shipped to 68803.
Re: WTB 1967 4 Jet Throttle Linkage
Like the rod that goes from the pedal linkage to the carb linkage? I have one I believe but I'm sure it's the same as all 67 70 V8's.
Just throwing this out there if "chewychevy67" does not have such. I have a threaded carb linkage rod at about the 11 3/4'' length with slight dog leg bend. Still has the threaded adjutment fitting and the plastic carb throttle plate bushing. Not sure what it originally fit, have had it for some time. Hard rod linkage ended about 71 or so with GM going to a throttle cable. Hit me up if chewy does not find his. Not wanting to crowd in, just trying to help out if I can. :chevy:
I haven't been out to find it yet and It would be cheaper and get to you faster from the US than Canada so go ahead and take one from iron horse. I still have this one if needed later on.
Wanted to get a pic of the linkage rod I have for you to look at before go any further. May or may not work for you. As mentioned, not exactly sure what it was originally from but have had it for quite some time. Mostly have owned and mech'd on GM cars and trucks so thinking maybe 90% sure is a GM rod but can't remember for sure.
Measures 11 3/4'' long with 1/4'' diameter rod and double dog leg bend. Includes the adjustment knob with rubber bushing and plastic bushing at the opposite end. $10 and $4 shipping to your door sound fair? |
Payment received and throttle linkage shipped. PM sent with tracking, thanks for the purchase.
Received today. Had to adjust the bend a little but otherwise works perfect. Thank you!
