Motor swap
3 Attachment(s)
I’m going to post up the progress of the engine swap in my 72 C20. It might not be exciting but it will be cool to look back on.
Started with a tired, stock 350. After getting it out, I sprayed the engine compartment with EZ OFF and power washed it. |
Re: Motor swap
2 Attachment(s)
Hit it with Satin Rustoleum
Re: Motor swap
Newness
Re: Motor swap
Blueprint Engines 365/405
Re: Motor swap
That is going to look good! Did you get a good deal on the engine? Too bad they dont sell big blocks like that.
Re: Motor swap
Re: Motor swap
Nice looking engine. Its going to look great in the truck. What Carb did you get it with?
Re: Motor swap
Love those "Ochre" paint jobs! L-31 motor is a good choice, looks good! ;)
Re: Motor swap
Nice job on the prep work! That's the hardest part.
Re: Motor swap
Re: Motor swap
Re: Motor swap
Holley 6210 spread bore is a great carb for those motors.
Re: Motor swap
Re: Motor swap
More progress today. I fixed a leak at the shifter shaft and changed the transmission filter today. I also installed a 2500 stall converter.
Re: Motor swap
Sub'd for the update on driving!
Re: Motor swap
2 Attachment(s)
New trans cooler lines this morning and getting the motor out of the crate.
Re: Motor swap
I really enjoy this thread. Im excited about how it will drive. The blueprint 355 i put in my 71 is a great engine. Sounds great, and great fun to drive. Im sure you will be more than happy with it.
Re: Motor swap
Re: Motor swap
5 Attachment(s)
I’ve made great progress today. I have spent a lot of time just piddling around with little things. I want it to be right when it’s done. It doesn’t have to be perfect and i don’t ever expect it to be but i want it to be RIGHT.
The motor is in its new home. The bellhousing and motor mounts are fastened. I went with Doug’s tri-y headers. Today was the first time they had been out of the plastic. They are a thing of beauty. I had considered going a cheaper route but as I said above. I want it to be right. I am happy. |
Re: Motor swap
That sir is looking sweet! Nice job.:chevy:
Re: Motor swap
More progress tonight. Slow and steady progress but it's still progress.
Got the torque converter bolts in. Driver side header. Fuel pump. Oil pressure line that if forgot to put in before I dropped the motor in :barf: Got online and ordered a few parts to wrap this up. It might run this week. -6 AN fuel line, fittings and filter Holley 4160 dual feed line Holley transmission kick down and throttle brackets Accessory pulleys Power steering pump Hi torque starter |
Re: Motor swap
I’m ready to get back on the road
Re: Motor swap
Nice looking work! Post videos of the new motor running if you can please, I'd love to hear it.:metal:
Re: Motor swap
Absolutely! :chevy: |
Re: Motor swap
Looking good, Can't wait to hear it
