Shifter boot ring help
I’m getting my shifter boot rings chromed and the vender is trying to determine which side is up. I believe the attached photo is the correct way any help would be appreciated
Re: Shifter boot ring help
Sharp ridge goes down … Or the last six I have used have been upside down =)
Lip goes down.
Thank you for all the help
From a logical standpoint, I say lip up. I only say that because if the lip is down, its going to be making contact with the boot and will eventually cut the boot. So by having it up, you now have a nice rounded surface that contacts the boot and prevents damage to the boot.
I agree, lip up as in the picture.
I did an image search of boot ring here on the board. Take a look and decide for yourself. I agree it seems like the lip as shown in your pic seems logical for reasons stated, but the pics show differently.
https://www.google.com/search?sa=G&d...h=778&dpr=1.25 |
The only thing I will say is that the screw holes are countersunk for the screw heads, so as long as the screw heads fit down in the countersunk holes that is the way the ring sits.... LockDoc |
well after a lot of review i'm going with lip down. see the letter stamped on the ring. it was not showing when they where installed. also i think the lip down will help seal the boot. Funny how something so simple on these trucks brings conversation.
Revised my thinking. I have seen several undisturbed trucks with the ring lip up. I also talked to several very knowledgeable guys on this forum that agree the lip goes up.
lip is up, countersink holes are down.
Thanks Russ |
