What is the function of this piece?
My 77 burban. This is on the cowl, strap with what looks like saw teeth.
Re: What is the function of this piece?
not sure.. but it looks like near the same place that on my truck is the "straps" to hold the washer fluid lines from the pump???
good luck! |
Didn't delve any deeper than taking the photo. I'll pull the cowl screens to look closer . Need to wax under there anyway:lol:
It touches the hood and is a goofy ground I believe.
I am also thinking some kind of ground
Yes it is a ground strap. Chevy used this on Corvettes that grounded the Air
Cleaner base and the Ignition Shielding. See Picture Below. Larry:chevy: Attachment 1985928 |
Wheres Keith?.....he'll have the answer
I dont think I've ever seen one on a truck before |
It helps with radio function (reduced static as a result of the hood functioning as an antenna). K |
Do you know if this is specific to burbs? or is it on all models (trucks) with glass antenna? I don't believe my truck has one... |
Never would have guessed the hood as a antenna..you the man Keith..
My 79 C35 has it. Antenna is in the glass on mine. |
My 81 C30 doesnt have one...antenna in glass on mine..
another thing I noticed Mark ..is your hood seal is on the cowl on your 77...my 81 the cowl seal is on the hood...but mine has a hole in the firewall cowl area that looks like its where your strap is mounted..
1980 and 1981 z28 has it to ground the air induction. my guess a ground for the hood light.
You can likely attach a braided ground strap from the firewall to a hinge bolt on both sides and get the same result. |
