Blazer windshield frame
5 Attachment(s)
There are a few holes on top passenger side but the rest of it is solid. This is for only the frame nothing else on the firewall/dash area unless negotiated. I will be pulling all of the dash components and listing them tomorrow.
$400 plus shipping which will depend on how much pillar you want left attached. EDIT: Just to be clear, this is only for the windshield frame. I am keeping the outer cowl and the lower firewall is toast. Windshield frame is SOLD . |
Re: Blazer windshield frame
3 Attachment(s)
more pics
I’m interested, any rough idea what shipping would cost to 33811??
My bodywork man says right above the top of door hinge please... I’ll message you address...
Ok will PM you tomorrow with shipping costs
Thanks |
Sent PM with shipping cost options
Still available
5 Attachment(s)
some more pics now that i have it stripped down more
can you take photos of the front floor area?
5 Attachment(s)
Richard, i need the ac flapper door cowl bushing and nut shown in picture 3 of post number 9.
I also need a 4wd vacuum pod bracket and a good plastic vac pod.
The shaft was broken off of the flapper and at the moment it is still stuck in the outer bracket. I have it sprayed with blaster trying to get it loosened up. Will let you know how I make out with that RH |
Picture of ac vacuum pod bracket which mounts to outer ac box, on engine side.
I need the screws with it if possible. |
2 Attachment(s)
Flap door layout and bushing which mounts through firewall with nut behind glovebox
The pictured bushing is cracked and part of it it missing |
I should have some. Give me a little while to get it all out
4 Attachment(s)
Randy
Here is what I have. $150 shipped for everything. While I had the bracket off I went ahead and made a new one as well for a pattern but did not have proper thickness metal here. The original is in nice shape with very minor pitting. No cracks in either of the plastic pcs that i can see. . |
I only need the firewall bushing and the 4wd bracket and Pod, whats the price on those alone?
4 Attachment(s)
$80 shipped
Money sent, thank you.
