Pics of your line lock install.
Good evening all.
Im in the process of planning my line lock install. Its going in my C20. Its just a fun truck, (cruises, etc) not strictly race. Could you all post pics of where you mounted the solenoid in the engine bay, and pics of the activation switch on the interior? Thank you, I appreciate the help. |
Re: Pics of your line lock install.
I got this from JEGS, might help... https://www.jegs.com/i/JEGS/555/63002/10002/-1 When you get that page scroll down to the instructions and they give you plumbing and electrical options and instructions. The solenoid goes on after the prop valve on the front brake line... https://www.jegs.com/InstallationIns.../555-63002.pdf
How was the installation on your truck? Where did you mount the solenoid? Thank you. |
Just find a good spot on your frame before the tee to the front brakes. You'll be good with that.
