WTB: 15 x 6 72 K10 steel wheels
FOUND!
Looking for a set of 4 steel wheels, 6 lug for a 72 K10. If I’m not mistaken these will be 4 nubs to fit the 72 disc brakes. Thanks. |
Re: WTB: 15 x 6 72 K10 steel wheels
Lastly can you get pics or let me the code by the valve stem? Thanks! |
Just make sure all four wheels match and they are straight. There are a lot of different ones with slight changes in patterns & offsets and sometimes it can be hard to get one to match.
5 Attachment(s)
Here is what I have left.
Here is a close up of the worst one after I wire brushed it.
Dwayne i was working ith Tom on a set of wheels, post a pic of th wheel code which is near the valve stem and make sure they are all the same. Also pic of the bead where the tire seats. Worst bead area on each wheel.
I can see the bead looks pretty clean on one white wheel and one black wheel. My wheels had rust in the bead area which i felt was a little too much to restore a set of wheels. |
Thanks guys. I found a set of CT wheels through Harlow. If it falls through I’ll be in touch. Thanks again.
Boom!
