What have you learned new about these truck recently.
Until recently I have never heard of a Sierra Custom Package for our trucks, but it exists.
What have you learned new about these truck recently. |
Re: What have you learned new about these truck recently.
I learned that 67 to 70 high beam Indicator is different from 71 72. It a rectangle not circular like the 71 72. I also learned you to remove the steering column. Did it yesterday. Super easy once you get it separated from the intermediate shaft.
Funny thing, Ive customized engines, overhauled transmissions, rebuilt differentials etc., but didn't know the bench seat in my truck would actually fold forward if I lifted the vinyl and removed one of the two bolts on each side. I have spent much time scouring salvage yard for a useable bench seat that folds forward. Wow! I used to remove the seat if I wanted access to the fuel tank area, never checked to see the attachment beyond the bolts through the floor! That has become an important discovery for me. Guess I should have asked.
That 67's have a one year only ashtray, of all things. Probably common knowledge for most of you, but perplexing to me when I tried to swap one from a 67 to a 68.
Something every day just by reading this board. An amazing wealth or knowledge and experience.
Latest is that the oil fill tube is pressed in. If PCV valve is clogged it was create pressure. To remove rear drums , you have to pull axles Etc, etc, etc. I know, basic stuff but all new to me |
I just recently did a search and learned that the front marker lights on a 67 are supposed to go out when the headlights come on. Thought I still had an electrical issue until I did a quick search. Also found out how you can make them stay on but I'm not sure which way I lean right now. Leave them off or have them on with the headlights.
Everything since I am new here. :)
I just learned that the a/c compressor kicks on on my '67 whenever the blower motor is turned on...regardless whether it is on heat or a/c. I looked underneath to see if something was mis-wired, but everything looks factory. Maybe it's right?
I was on quite a run but nothing lately. Last thing I learned was tailgate latch rods attach using push-through spring clips.....Nothing to write home about.
I've learned that you better learn as much about your truck as possible and fast and be willing to do your own repairs. It is getting real hard to find a mechanic that can fix anything without a code reader in their hand. Sites like this are next to God when you have a problem. Keep up the good work eh. Have a good one.
PS. I've been to many AC shops to fix my AC and same answer, we can't find any thing wrong, everything is working. I found an "old" guy and he solved it right away. Everything was working and so was the heat valve when calling for AC. The crazy valve was stuck open so was heating my cool air. I'm freezing now and still on R12, no leaks, no change. |
The knowledge on this board is amazing.
I recently learned that the aftermarket upgrade A/C POA valve sold for these trucks and a lot of other GM vehicles, is actually a P.O.S. valve....junk! Don't waste your money, get a rebuildable original and keep your sanity.
I forgot I recently learned 71-72ish tailgate latch bolts are stamped RSC. I was missing one of four for my project, go figure my 72 had four:chevy: |
A little over a year ago (does that count as recent?), I learned that all '72 3/4 ton trucks came with power brakes, and therefore, the power brakes option is not listed on the SPID for 3/4 ton trucks in '72.
Post #9 here: http://67-72chevytrucks.com/vboard/s...d.php?t=776630 |
Follow the cable to the box and you'll find the switch on the back side. :chevy: |
Nothing concrete yet but a member posted that his Spid shows front and rear sway bars. I know our trucks came with a front sway bar but have never heard of or seen a factory rear sway bar on our trucks. No pic of the Spid but the member says he will take one and post it and if a rear sway bar was available on our trucks that will be what I have recently learned about our trucks.
My original POA valve was a Delco brand which can be cleaned and recalibrated (if still good) but not rebuilt, the Fridgidare brand can be opened up and rebuilt. Original Air Products has a service for these but it is quite pricey. I found a good used Frigidare brand on eBay that had been cleaned, tested and calibrated for R134 for a reasonable price, I figured if it ever goes bad I have a rebuildable core....works like a charm as is. |
I have been slowly fixing my GMC. There are alot of parts that are interchangeable between The chevy's and GMC but not everything. And every so often I find something that won't inter mix. Like I have been changing my lights and turn signals over to LED's. They do not make a LED for my front turn signals. They also don't repop the housing for them, at least I haven't found any.
That u could order your blazer yellow and it showed up at the dealer orange
