Frame bracket with a cable under the power brake booster
I recently bought a 69 frame and cab with a strange frame loop with a cable and another bracket attached to the cable. It wasnt attached to the cab and im not sure what it is. Andy input is appreciated!
Re: Frame bracket with a cable under the power brake booster
Here's a picture of the bracket.
LockDoc |
Yep that was a early "Fix" until they came out with the no break version of motor mount
https://www.chevyhardcore.com/news/motor-mount-recall/ |
Were they on small blocks or big blocks or both? Thanks!
It was particularly a problem with V8 engines with a rod-type throttle linkage. If the motor mount broke, it could leave the throttle open.
You haven’t lived until you’ve have a broken mount and it goes full throttle.
Been there, done that. |
Here's the recall letter which I posted on another thread last week.
A full installation would of had a pieces on both sides of the engine. See the link to Hardcore Chevy to see the other side pieces.
That pretty interesting, that you actually have the recall letter. I wont be using the bracket for my build because of a ls swap.
2 Attachment(s)
