Need some help with coil spring replacements
It has become apparent that part of my covered wagon ride quality is due to sagging coil springs. The rears in particular have multiple coils touching with the weight of the truck on the ground.
My Suburban is a 1972 3/4 ton C20 that came with the 402 cu. in. big block. Looking at the specified replacement springs from Moog: Front: 6104 constant rate Rear: 6101 constant rate 6103 constant rate heavy duty CC603 variable rate CC615 variable rate heavy duty So with only one option for the front, that decision is quite easy. My question is, what are the proper springs for the rear to match the front? I'm assuming the HD springs would be used in a truck that saw frequent heavy loads or towing? I'm also not sure variable vs. constant rate. Any input would be greatly appreciated! Thanks Greg |
Re: Need some help with coil spring replacements
I went with the gmc Paul’s front bb springs and rear 4” drop. The fronts are identical to stock and the rears are much softer variable rate. Rears are nice for a softer ride but towing capacity is definitely dimensioned.
Here's some links that may help with the decision.
http://67-72chevytrucks.com/vboard/s...d.php?t=336257 http://67-72chevytrucks.com/vboard/s...d.php?t=776387 |
