Timken PN for rear end Bearings
Anyone have the pn's for Timken Bearings ? its a 12 bolt... the guy at the parts counter was not exactly helpful today.. :waah:
Re: Timken PN for rear end Bearings
You need numbers for all of the bearings and seals or just some of them?
rear wheel bearings and seals , and pinion bearing and seal
thanks |
I bought a kit from USA Standard Gear. ZK GM12T and there is also the number 37043 on the box. It has Koyo bearings and I used the carrier bearings so no cross reference for them. The pinion bearings are HM89449-N for the big one and what I read as M88048-N for the small one.
https://feyc.eu/download/catalogos/r...er-Bearing.pdf https://www.dennysdriveshaft.com/c23...end_parts.html |
The only numbers I had saved that you need are as follows
Front pinion bearing M88048 Front pinion race M88010 Rear pinion bearing HM89449 Rear pinion race HM89410 Pinion seal CR17190 I would verify those numbers with what you remove before just installing them. |
Thanks bud !!
