Cam Downgrade
Guess I'm officially old now. Getting tired of the cam in my new crate engine. It has great power but the idle is pretty bumpy due to a 108 LSA. thinking about going to mild cam with a 112 LSA or similar or even the stock L31 cam. Has anyone done this and did you really notice any loss in power during normal driving? I know I'll lose some top end power but what about the low end?
Re: Cam Downgrade
Dude the stock L31 cam is pathetic. At least get an LT1 [gen2] cam.
Best option would be the smallest modern grind. I think comp has like 203/210 with a 110lsa. |
Re: Cam Downgrade
Go custom grind so you can get that 114 lobe separation and still have some duration. Look at the LS cams and you will follow what I am saying. The only concern will be DCR if the crate motor has alot of compression to begin with.
Re: Cam Downgrade
Re: Cam Downgrade
looks like the LT1 cam has a little too much lift. With Vortec heads max is about .480.
Re: Cam Downgrade
Re: Cam Downgrade
Marine cams or nitrous cams are great street cams for smooth idle and decent power. Looking through Comp's catalog there are a lot of options.
The XM262H has 218/224 @.050 and 112 lsa. And the XM256 is 212/218 @ .050 and 112 lsa to really smooth it out. |
Re: Cam Downgrade
94666492
