Tahoe Floor Access Plate?
Really curious as to why GM never put a removable access plate above the fuel pump on Tahoes, Yukons and Suburbans? A simple 12'' x 12'' plate configured to the floor above the fuel pump would make a fuel pump replacement SO MUCH EASIER! Had the pump replaced on our '99 Tahoe and required dropping the tank. That SUCKS big time. With just buying this '05 Tahoe the thought crosses my mind to do such if ever have to replace the pump rather than dropping the tank.
Thoughts on this would be much appreciated. Anyone ever done such a modification to their Tahoe or Burb? |
Re: Tahoe Floor Access Plate?
That would make it smart. Mywife's old Kia was that way, although we never needed it in 180K.
No access panel on burbs or Tahoes that I'm aware of. My 2002 Yukon XL had dual tanks and no access panels from above, had to drop both tanks to replace the pumps. The main tanks are under the passenger area floor.
Understand about the lack of floor plate access panels. Just think it would have not been that much for GM to install them going down the assembly line. A bit of consideration and forethought would have been nice on their part. Have owned three Suburbans and two Tahoes and always thought that lack of an access plate was poor thinking on GM's part.
I installed a fuel pump in my 07 classic and and just cut a hole in the floor. Now I'm looking for a pach panel. They don't make them. Make it much easier the next time to.
had to drop the tank in my 2000 tahoe to change the tank presure sensor honestly wasnt that bad but then again i ran fuel down to almost empty
I cut one into the floor of the 2dr 97 Tahoe I owned. I used rivets to add flanges around the edges and screwed the panel to the flanges. A little HVAC duct sealer tape went over the edges. Careful measurements made the job look almost factory, sorry, no pictures.
