My 58 Brookwood
4 Attachment(s)
I bought this 58 Brookwood sight unseen for $8000. It had a 235, tattered interior, and no floors. It did however come with all the patch panels. Ran and drove great. The bags and the 18/20's were already done. However, the PO didn’t put front shocks on it.
Re: My 58 Brookwood
Cool car, nice find
Re: My 58 Brookwood
2 Attachment(s)
here's the air setup. 1 gal tank with single compressor. I think I'll move it to the spare tire well. Increase the tank to 3 gal, and add a 2nd compressor.
Re: My 58 Brookwood
I also bought a weld in relocation kit for the front shocks.
Re: My 58 Brookwood
Nice wagon..!!...I saw it I one of your other posts somewhere sitting in the background and wondered about it
Re: My 58 Brookwood
Re: My 58 Brookwood
3 Attachment(s)
The first issue we had was the drivers window kept falling off the track. Eventually it shattered. The problem with the window track was that the lower half had disintegrated, and the reason the window shattered was a to long screw. So taking it apart we broke off one of the bolt bosses on the vent window regulator.
Re: My 58 Brookwood
3 Attachment(s)
So I got a parts car because I found out they don’t reproduce that window track. All the windows go up and down smoothly.
Re: My 58 Brookwood
3 Attachment(s)
The first thing we needed to address was the floors, they were pretty well ventilated. And it was probably none to safe to drive!
Re: My 58 Brookwood
4 Attachment(s)
Bear in mind that this is Alex's first Time welding, well anything that wasn’t scrap. I think he did a great job. Just to be sure we coated all the welds in Flex-Seal.
Re: My 58 Brookwood
5 Attachment(s)
Then we covered the whole floor top and bottom in spray on bedliner. Now it just needs new jute, carpet, upholstery, door panels, and windlace.
Re: My 58 Brookwood
Looking good, amazing that you found a parts car.....
Re: My 58 Brookwood
4 Attachment(s)
Then the old 235 gave up the ghost. It started putting out a smokescreen and losing power. When we got down to 30mph on the open highway, I decided it was time for a motor! But it had to be the right motor. After some looking around I bought a good gen IV 6.2L LS3 short block.
Re: My 58 Brookwood
3 Attachment(s)
As unlikely as it sounds, I really liked the idea of rowing through the gears! For the amount of power I intend to put to the pavement, there was really only one choice. Although quite spendy a rebuilt Tremmic T56 was picked up and an LS7 clutch.
Re: My 58 Brookwood
Sounds like it's going to be quite the cruiser.
Re: My 58 Brookwood
5 Attachment(s)
The boys are installing the Brian Tooley Racing V2 Stage IV cam. 274/280 adv duration on a 109 LSA. LS7 lifters and matched BTR beehive valve springs control the valvetrain. I got some reman ported 821 heads, a velocity fabricated 102mm intake, planning on recapping the injectors to flow around 80 lb/hr. And 1:7 roller tip aluminum rockers. Should be able to get out of it’s own way!
Re: My 58 Brookwood
That oughta move that big ol tank
That's some nice parts..! |
Re: My 58 Brookwood
I love these old wagons....Looks like a great projects....
Marc |
Re: My 58 Brookwood
I love it! Guy down the road from me has a 69 malibu wagon that is super sweet.
Your ride reminded me of this photo I took at the gym the other day. Guy that owns the gym is a developer and a car guy. He had these two rides parked there so I took a quick photo. Pay no attention to my 4Runner, I parked it there knowing I would not get door dinged on one side. |
Re: My 58 Brookwood
Thanks all! Those two rides are sweet! I even bought a set of 15” Supremes and some Coker wide whites so I can attend Grease-a-rama.
Re: My 58 Brookwood
Re: My 58 Brookwood
If you think one compressor will be fine, I’ll give it a try. I have a spare windshield just in case!
Re: My 58 Brookwood
5 Attachment(s)
well it's been collecting dust for quite some time! I added an authentic (not reproduction) swamp cooler last summer.
Re: My 58 Brookwood
3 Attachment(s)
we finally started putting that motor together yesterday! the BTR stage IV cam went in, spent most of the day looking for parts ordered eons ago! cleaned up the pistons and cyl head gasket surface.
Re: My 58 Brookwood
Love it..!!!
