Learn from My Mistake - LIFT GATE ACTUATOR KIT
Hi All,
I'm not usually one for griping online, however, I'll make an exception in this case! ;) Here is the story: I had been kicking around the idea of adding modern/gas charged lift gate supports to my vehicle this summer given the increased use the tailgate gets. After doing a bit of research, I purchased the "67-72 SUBURBAN LIFT GATE ACTUATOR KIT" sold by Brothers Trucks. While a bit pricey, at $130 ($99 parts, $21.50 shipping, $8.50 tax), I thought the better functionality/reliability was worth the splurge. Had the fit and function of the new supports been perfect, that would probably would have been the end of the story, however, the "extended length" of the supports was a fair bit shorter than the OEM supports, so I did a little more research. What I found is that the EXACT product I was shipped from Brothers is available on Rock Auto for $30 ($19 parts, $8 shipping, $3 tax). Link to parts page here > https://www.rockauto.com/en/parts/ul...t+support,1404 I'm all for paying a little "marketing markup", but $100 markup is extreme in my book. Sadly, while I would return the supports to Brothers and just re-buy them from Rock Auto, but I'd have at least $50 in the deal between shipping both ways and Brothers' 20% restocking fee. This falls in the "fool me once" category for me. I hope others can learn from this and save themselves some hard earned $. |
Re: Learn from My Mistake - LIFT GATE ACTUATOR KIT
Thanks for pointing it out.
Wow not good. Thanks for the heads up. One question. How much shorter is the lift? Thanks in advance.
Given my overall setup (2" suspension lift, 30" tires, and I am 5'11"), I am not banging my head on the open hatch now, but a lowered Suburban with a taller owner might . . . The fitment isn't the end of the world, and the supports are a big improvement over OEM, I was just chapped to find out I overpaid by a wide margin. |
I'll see if I can dig up the part number, but if memory serves me correctly the struts I'm using on my Suburban are off a Volvo station wagon...I think I paid $40 for both on Rock Auto and they hold the door up as high as you could possibly get it.
I would love to see the kit used for Blazer hatch lifts as well - cheapest I could find was $150 before tax/shipping for a set of plates/bolts/struts.
Same theory - cost of parts off is likely way cheaper than $150. |
The Beach-Burban had a set of lifts on the hatch that were completely dead when I got it, so I bought a new set online from "Lift Support Depot" for $18.90 each. Easy install for me because the ball studs were already in place! They are USA made by "STRONG ARM", model 4220 (which I believe does fit the Volvo Wagons as FLYNAVY30 said). Specs are: 21.50 extended; 12.75 compressed and 81 lbs of force (goes up very nicely, plus it's very comical watching my wife try to close it!). I feel very confident that the hatch won't come down on us while sitting on the tailgate. These would be way too HD for the Blazer hatch, though!
Woody |
Years ago I replaced the factory truck springs in a 73 Challenger with some struts I got from Mcmaster Carr. I got a fish scale and used it to get an idea how much lift I needed then divided that number by 2 and bought the nearest rated struts. I went to the nearest over pressure as struts in my experience will always loose pressure over time.
They even had ones you can bleed off pressure to get exactly what you want in lift. (One time only) I think I was into it about $60 when I was done. https://www.mcmaster.com/lift-struts |
