Jimmy update - a question and 2 vintage accessories
3 Attachment(s)
I got my new to me Jimmy over to my property two weekends ago. I got it with grille off, radiator out and no carb on the engine. My brother and i got some oil in the cylinders and let it set overnight. #1 & #3 cylinder 100 lbs compression #5 0 lbs compression and #7 75 lbs compression. We figured #5 was a collapsed lifter or stuck valve. # 7 had a fair amount of corrosion on the push rods. So we yanked it out and put in an engine I bought with a pile of parts this spring. We had it in an engine cradle and hooked it to a battery and poured a little gas in and it fired immediately. In about 8 hours old out and new in. only bad discovery - some nit wit had cut the exhaust off with a sawzall and got 1/2 way thru the front drive shaft!
Questions? The locking gas cap on it was loose and all corroded. i got it off and got a good cap off a C10 tank I had kicking around. It was too small? Is the Jimmy gas cap slightly larger? Also, can I weld up the front driveshaft and grind it smooth without balancing it? My jimmy looks modestly modified - it has some weird old mileage computer and a CB in it. Pics attached. Any idea of era for either? |
Re: Jimmy update - a question and 2 vintage accessories
I think the computer was a mileage calculator
Posted via Mobile Device https://www.mercari.com/us/item/m20515322469/?gclsrc=aw.ds&utm_source=google&utm_medium=cpc&utm_campaign=1822972057&utm_content=t0&adgroup=663623 89821&network=g&device=m&merchant_id=133458120&product_id=m20515322469&product_id=527918100373&gclid =CjwKCAjwjqT5BRAPEiwAJlBuBauNJ4C0cat_2ZnSpna3KnP50wsoVbHBoGOa4ejqL84WNLRjwggB-hoC420QAvD_BwE |
I found an old ad on the internet. 1980's vintage computer with cruise control.
