WTB--License plate light "hold down"
I am looking for the piece that holds down the glass for the license plate light. I have not seen it reproduced, but if you have one or know of a repop that would be fine as well. PM me or post here if you have one. Thanks
Re: WTB--License plate light "hold down"
That's a tough one. Just in case you need it though - https://www.cjponyparts.com/rear-lic...-1966/p/LPB58/
Goodmark makes the whole thing - https://www.goodmarkindustries.com/c...42-885-60.aspx or https://www.classicindustries.com/pr...s/ct26699.html Just a bear. Have you called Aspen in Arizona? |
Yeah, I knew it would be a needle in a haystack. I got overzealous with mine in the blaster (oops). I can probably use it, but ...
Good idea on Aspen..I always forget about them. I have the repop in my cart from LMC since I am ordering some other parts from them, but wanted to try and find an original one first. Thanks! |
I ordered an entire new license plate bracket since I was ordering some parts anyway...If someone has the part I need, I would still be interested. Otherwise, I will let this drop and won't bump it. Thanks
might have a powder coated one. Pulling some other parts later this evening so will check.
That would be awesome Dwane...thanks for checking!
2 Attachment(s)
PM Sent
If I decide to keep the new one, I will contact you for the OEM. Probably be about a week before I have the new one. |
