Sbc swp alt .bracket and pulleys
I have a assortment of oem pulleys for drivers side alternator. With power steering or not .plus air if you need.crank .water for are trucks.pcice depends on what set up u need.67-68style or69-71 style
Re: Sbc swp alt .bracket and pulleys
Bump
If in good condition, straight without rust, I'd be interested in the pullies for a 67 327 with power steering AC and of course the alternator, also, maybe the bracket for the power steering pump, Thanks
I ll get pics tomorrow I dont have ps brackets that I'm going to get rid of.this is on a 68 but I believe it's the same
Pic would be nice, thanks
2 Attachment(s)
Here's pics first pic is of 68 set up waterpump is. Atwo groove crank is a 4 groove that what you need for alt.air smog and ps. I was trying to tell you about the small bolt pattern waterpump pulley.the crank is 2groove steel and a 2 groove cast outer pulley
The second pic is of a 2groove waterpump large hole pattern also that pulley is smaller in diameter .the crank is a 2 pulley steel and a 2 groove cast or a steel 1 pulley add on |
Ttt
Can you send me the part numbers stamped on them?
Bump
Do you have a 2 groove inner crank pulley for A/C? If so how much shipped to 72616.
Thanks, Bill |
Ttt
I will take it, let me know how you want payed.
Thanks Bill |
Pay pal---- gurtrude_50@hot mail .com. Thanks. |
Payment sent.
Thanks, Bill |
