4L65E transmission
Greetings, i got this transmission out of a all wheel drive vehicle along with the LQ9 that it was attached to. I plan on installing both into my C20. I think i need to change the output shaft and the tail housing. Is there anything else i need to do to it to make it work in my 2 wheel drive C20? Thanks for the info
Re: 4L65E transmission
Output shaft and tail housing needed...trans must come fully apart...good time to reseal it etc...there are several threads about overhauling 4l65E units...
Consider what type of speedo you will be using...digital from the factory sensors or manual or GPS based???? What trans controller are you intending on using? :chevy::chevy::chevy: |
