Name the tool
2 Attachment(s)
I have a tool a friend made me about 15 year ago. Anybody want to take a guess at what it is used for?
He personalized it for me also.:chevy: |
Re: Name the tool
Breaking loose a fan?
Re: Name the tool
Diff yoke holding tool, just like the one I made for the Toyotas I do
Re: Name the tool
What do I win???
Re: Name the tool
It already has a name. Pimp Daddy! Is it for holding a flywheel or flex plate?
Re: Name the tool
None are correct so far. I will post the correct answer tomorrow.:chevy:
Re: Name the tool
Looks about the size of a golf cart hub with 4 lugs ? Is it used to hold the axle/ rotor when changing bad bearings ? :smoke:
Re: Name the tool
Sharpen the edge and you'd have a dandy tomahawk.
Re: Name the tool
Old School Customs eh... Well it is a nice looking piece for sure but I really wish some scale could be made out in the pictures I mean this thing could be 5 ft long LOL!!! I'm going to guess that it is only about 16" or so, probably less. Appears to me it's a leverage buying instrument of some sort. The central opening likely catches the center of a hub and the smaller openings gather two or more protrusions ( studs/nipples ). The handle is then used to stabilize the rotation of the now captured "thing" so that torque can be applied. I have no idea what the "thing" would be though. Maybe motorcycle parts, golf cart or small engine parts? It would be something that you work on often or otherwise no need for the tool. -klb |
Re: Name the tool
A tool that is handy for doing brake jobs on a golf cart?
Re: Name the tool
It's for a golf cart rear brake hub to break the castle nut loose when taking the rear hub off for brake work. It would be the same for the bearings. Quote:
My good friend Eddie Hill made this for me after I did my first brake job on my 89 Ezgo. I posted about what a pain it was holding the hub with a screw driver to break the castle nut loose. He made it without saying anything until he gave it to me. Eddie passed away from cancer a few years later. Things like this are what makes life so special to me.:metal: |
Re: Name the tool
It could still be a tomahawk - a dual-purpose tool.
Re: Name the tool
Yea I guess. In today world it would be a good tool to have handy on the road no doubt!:chevy: |
Re: Name the tool
So you don't loosen the castle nut before jacking up and taking off the wheel/tire ?
Re: Name the tool
Re: Name the tool
Some guys used to service wheel bearings (rwd front & trailers) without even taking off the tire/wheel. I was always afraid that I would damage the seal or something trying to remove & replace the hub with all that extra weight. And I was thinking about the big axle nut on fwd and ifs 4wd: you darn sure want to loosen that thing before you jack it up, if you're going to replace the axle and/or the sealed bearing hub. |
Re: Name the tool
So holding it is the key to getting it off once jacked up.:chevy: |
