Rochester 2GC Woes
I have a 68 K10 with the original 307. Original 2 barrel carb, Pertronix ignition, new fuel pump. I've rebuilt the carb and gone through it a couple of times due to leaks at the throttle shaft. Not a lot of play evident in the shaft mind you but just can't get it to run right and the leak makes me want to upgrade to a more modern, new carb. Any recommendations?
Thanks, Dave. |
Re: Rochester 2GC Woes
Those leaks are caused by flooding.
Could be a fuel pump putting out too much pressure or a float level that needs lowering. Lower the float first. Go 1/8 inch lower than the normal setting. Sometimes you can hear the flooding in the carb Venturi. Listen for a crackling sound. My ‘motors manual’ shows a float setting of 9/16 inch. |
The '70 and newer carbs you can get a new one, but not the 69 and older. You could convert but need to make choke work somehow. Change intake? You can get a throttle shaft bushing kit on Amazon for $40.
Wish I had asked Geezer#99 about this a month ago, too much fuel pressure. 5-6 psi for a Rochester 2 jet.
I suggest call National Carburetor and see what they can do for you. They can probably outfit you with a new one exactly like yours, or put together a more modern one with throttle linkage suitable for 1968. They built a Quadrajet with electric choke but push rod style throttle linkage to replace my original Quadrajet for my 1969 pickup. It was inexpensive, it just works, and has a lifetime warranty. For my truck there was no difference in cost between 1969 carburetor or the more modern 1981-86 carburetor.
Thanks all for the inputs here. I'll re-check the float level and give it a try but I kinda suspected that perhaps the fuel pressure might be an issue as well and will get a regulator or pull the one off my Scrambler and see if that helps (assuming float level doesn't help things). I had read somewhere that sometimes the new fuel pumps really challenge an old style carb. Since it's 100% original I'd like to keep it that way if at possible. Will update as soon as I get a chance to putz with it this week. Once again, thanks for the quick inputs here. Cheers, Dave.
If you have any rubber fuel line between the pump and carb you could give it a light squeeze and see if that helps.
I replaced the 1st new fuel pump, with a Carter m6624...from Rockauto....Looks exactly the same outside, specs says minimum 2 psi....I think it's going to be ok.....I started to do the fuel regulator also...Not impressed with what's available..... Will follow up in about a week.
I had the 2Jet on my 71 C/20 rebuilt by carberatorusa.com , ask for Joe, did a great job for $200.00:metal:
