turn signal switch
I have put a tilt steering column from a 1970 Camaro in my 66 truck. I am putting a remote horn button in place of the horn ring. I have found the correct wires to change for this but I can't find what the tan-green/tan wires are for on the switch. Can someone tell me what these wires ae for?
Re: turn signal switch
If so we need the info of what switch your using to help you.:chevy: |
The best tool to have when mix/matching electrical components is wiring diagrams for both vehicles...
If you are talking about the turn signal switch and two wires to it , a tan and green/tan wire. Does your signal lever also dim the lights and if so they might be the wires for the dimmer switch.
Here is a picture of a 70 Camaro tilt column switch does yours look like it. Attachment 2058624 |
Try this link about half way down is the 70 turn signal diagram. It maybe for the key buzzer.:chevy:
https://www.painlessperformance.com/Manuals/20112.pdf |
