Need help decoding block
3 Attachment(s)
Looking to ID the engine we pulled out of one of my Grandads GM trucks.
was a 69 flat bed dually truck casting # ML 24800 |
Re: Need help decoding block
thnx
so.. from that
3970010....327.....69....2...Trucks and industrial small or large journal? |
3970010 is the most common SBC from the very late 60's to 1979, and 99.9% are 350's
This link below has ML .
ML 1967 327 air cond. 275 4 F X ML 1968 327 s h/p 325 4 Chevy II Link:http://www.gregwapling.com/hotrod/mo...rs-hr-tbs.html Most of the time the first letter is Plant. From this link:https://nastyz28.com/sbchevy/sblock.html Code Engine Plant Code Engine Plant F= Flint (Motor) S= Saginaw Service H= Hydramatic T= Tonawanda K= St. Catherines, Ontario(McKinnon Industries Canada) V= Flint (Engine) M= GM of Mexico . |
Warren is correct almost all 10 blocks are 350 ci
To inspect further you will need to pull the oil pan and see what crank number you have to fully id weather 350 or truck 327 Its a large journal block |
pulling pan.. :-D
Made in mexico block is surely a goodwrench motor from the 70's
Check for the original paint on the block, but best bet is an older (probably 80’s vintage?) GM Targetmaster replacement block/engine. That is a generic casting number that will only you basic idea of engine. It was used for early 327’s and 350’s starting in 69(?) on up to the late 70’s in passenger cars. It also the reason the head pad has a weird stamped number. Normally they would read as a series of letters and number like listed in the nastyz28 site. To the left of the number would be partial VIN for the vehicle it was installed in if a factory installed engine. The alpha-numerical sequence where yours starts with an “m” would tell you the engine foundry/assembly plant, what plant it was installed into a vehicle at. That most definitely is not an original engine from the factory. Probably a crate or GM dealer, non-warranty replacement.
Side note though, if you find and engine you have an issue decoding, email the casting and head pad stamping numbers to the GM Heritage Center. It will take a few weeks, but they will email you back to confirm year/make/model, engine specs and where assembled/installed. I have done it for a couple of engines now and they are more than happy to help you out. |
This casting number was common in trucks 69 to 79 was the last year they used this casting number
It's all about the stamped #, not the embossed casting #. But usually it's the suffix code. This is a prefix code. Does that mean it's a Mexican block?
I guess prefix means replacement block. Now I see the Made In Mexico embossed above the casting number. So in this case we can somehow identify the block by the casting number? Or is it since it is a replacement block it can't be identified as from any particular model?
Special-K what I found in lots of downtime reading at work this summer, is those Made In Mexico blocks with the stamping in the head pad that begins with an “M” are untraceable as far as what they went in. They have no partial VIN nor the engine plant / vehicle assembly plant stampings. It is more of a serial number than anything with no VIN. Again that is just what I discovered researching engine stamping/castings. I’ll try and shoot the GM Heritage Center an email just to pick their brains.
Good info so far. Thanks
The 010 block first year is 1969. It is always a large journal crankshaft, so 327 and 302 (Z28) in 69 and 350 69-80. Pre-68 327s were small journal cranks and 68 327s/302s used a different block casting. 010 blocks can be either 2 or 4 bolt mains. Pretty sure none of the 69 302 or 327 blocks were cast in Mexico.
More than likely a 350 Targetmaster over the counter engine. |
