Are all these early trucks noisy going down the road?
Got the new clutch installed, went with a 12”. Everything bolted up just fine, trans slid right into place. Took it for a drive and it drives better than before but it still sounds like a Pettibone crane driving down the road. Damn, are all these trucks this loud? I know the clutch isn’t making noise, just seems like the trans or driveshaft is noisy.
Re: Are all these early trucks noisy going down the road?
4 speed? Yes, noisy. Sounds like a concrete mixer to me. Straight through fourth gear 1:1 is quiet.
Makes me think of riding the school bus when I was a kid
Yes these old trucks are noisy, especially a C20 with the Eaton HO52/72. They just are not going to be quiet in stock form.
What have you got for floor covering at this point?
I know where you’re going, floor insulation and a mat. |
Fer sher, and my truck was noisy as all get out without the floor too. Incredibly so, actually.
I’ll probably just do a rubber floor mat. |
For the deadener, I used Kilmat and went over it with Noico Red 315 mil closed cell foam as documented by me in this thread. https://67-72chevytrucks.com/vboard/...d.php?t=814233
That should cover the floor, right? |
Yeah, but dont overlook the benefits of using the butyl based deadener strips on the large flat parts first. Especially the outer door skins and the tranny hump. (I didn't put closed cell foam in the doors though because water gets in there, but the butyl sure did make them a whole lot less tinny.) I saw a deal on the web where a guy uses a cymbal. He didn't need to cover the whole thing with butyl to stop it from resonating...just 30 to 70 percent coverage kept it from droning on. Butyl stops the resonance and closed cell foam absorbs the noise and insulates too.
Yes, the first layer is deadener. I covered around 70 percent of the entire floor using strips and strategically placed squares and patches. Some folks go with less, some folks cover everything.
The next layer for me was closed cell foam. After that, I put jute pad and carpet which has an option called "mass backed" which means the underside of it is really heavy on the plastic material that binds the fibers. They say that helps to further deaden sound. Edit: and open holes in the firewall transmit a huge amound of noise. I made sure to fix evey one of those too. |
I honestly think heavily insulating the truck would detract from the whole thing, but maybe that's just me. |
And, I don't mind the experience of driving an old truck, I have just never had a truck this old before. |
3 Attachment(s)
Are all these held in place with spray adhesive? |
I'm not sure what to recommend , I only have experience with the products I mentioned. I do think however that in the case of going with the bare essentials, I would go with the two sided version of the product on the left. I did use something very similar myself as my last layer before the carpet and didn't have to use any adhesive. I also agree with what OEM4me says as long as I'm not driving for more than an hour at a stretch. But I love a long drive in my old truck and my hearing is not what it used to be so I do tend to go to greater lengths to conserve what I still got.
Turn up the volume on the 6x9 Triaxial speakers.
sound dampening everywhere you can. i put some inside the door panels, back cab wall. i also made a headliner out of masonite and sandwiched a piece of jute between that and the metal roof skin to help with noise and heat from the sun.
Could be rear end ,if noisy it could resonate right up the drive shaft . I've had a few different 3rd members of different ratios in mine with different noises at different times like accelerating , or off throttle . I finally found the ratio that works best for me that was fairly quite but had a slight lash when going between on and off the gas so I had a shop go over the rear end who adjusted the lash , and now the thing screams like a banshee when accelerating . I'm told the gears have to wear back in , but after 6,000 miles it still screams so I will replace it over the winter.
My truck is a one ton panel and I can hear every little noise from the back so a quieter rear end is a must . My trans. is a t5 which has been there through all the rear ends and is fairly quite . John |
Ok - I had a friend drive the truck; stuck my head out the window and the noise was obviously coming from the rear end. He also did the same and agrees.
Also, standing outside the truck, as he pulls away or drives by it is pretty obvious more noise is coming from the rear of the truck. My question, would this likely be worn bearings? Do you guys think replacing the drum/wheel bearings remedy this problem? |
If you are not leaking lube from the wheel bearings into the drums, they are probably OK. Can you post up a video with the noise?
Unfortunately I did not take video. |
