Quick part out. 70 1/2 ton 2wd
4 Attachment(s)
Heading to scrap in a couple of days so if you see something, i will price it.
Air cleaner and riser tube. $25.00 Visors, clips and mirror, $30.00 Grill and insert, $150, no shipping. 6 cyl finger guard. $15.00 All plus shipping unless indicated. |
Re: Quick part out. 70 1/2 ton 2wd
3 Attachment(s)
Couple more...
any of the 4 blue door escutcheons in decent shape?
Battery tray? Horns? E brake cable
I can see $500.00 worth of quick parts there, but understand when it gets cold and nasty we just want them gone..... Not to mention the mess this year has been.
Door hinges and bolts?
Price and condition on e brake cables and frame support rods and trailing arm brackets? Just need the wire type cables between trailing arms and end of cable from firewall (hope that makes sense) Shipped to 99337 if that’s something your willing to mess with.
Spare tire bracket shipped to 66032?
Man, I sure could use a throttle cable for a 250/292.... Mine is '71 if it matters.
Thanks, P |
And I'd be interested in the thermostat housing also-
thank you P |
The heater control, is it intact? My faceplate is screwed to the control levers as the rivets are broken.
Sounds great thanks
No worries.:ito:
Thanks.:chevy: . |
Eric, you might want to consider grabbing that Sparkomatic 3spd shifter, they seem to bring anywhere from $50-$150 on eBay.
Radio? Don't care if it doesn't work.
Is the washer fluid bottle still good, and how much???
Gotcha' I thought it was a factory unit, thanks!
Thanks! Thermostat housing to 77076
The '71 throttle cable was junk, it only lasted 49 years of regular use! P |
3 Attachment(s)
5 Attachment(s)
Rad hold downs, $20 shipped. (Narrow rad)
Decent set of driver quality lenses. $30 plus ship. 1 red side marker may need a shot of glue on the edge. They also need a good cleaning. |
Alt with 6 cyl brackets and bolts. $30 plus ship.
I am probably not shipping any items until early next week. |
