More Panel updates published in our website.
I just finnised publising a couple of pages of updates on our Panel Project. Check them out and let me know what you think.
http://www.classicheartbeat.com/67_panel_project.htm WES www.ClassicHeartbeat.com |
Wes,
Any news on the panel patch panels? and other assorted panel parts. ha ha say the last of that phrase three time quickly |
PM sent. :D WES www.ClassicHeartbeat.com
ttt:D
Wow, looks like you've been putting alot of hours into it. Nice job! :cool: Looks like you're setting up to put an under the dash unit in, what kit are you using?
Nevermind, I found it. :rolleyes: :D How much does "Old Air" cost?
Looking good Wes!.
Either $939.95 or $959.95. It depends on what outlets you want or have. $939.95 is under dash outlets and $959.95 is for the in dash outlets. The one that I am going to use for my Panel will adapt over to the stock A/C outlets and also allow for the 72 rear air system that I am installing in it also. WES www.ClassicHeartbeat.com
When do you expect this project to be on the road?
Thank you 70c10. I appriciate it. WES
Well I am hoping for spring. I want to hit all of the shows and swap meets with it this year. That may be a little optimistic though... WES www.ClassicHeartbeat.com
what are your plans for the paint and interior on that ride? thats gonna look sweet:burnout:
I have decided on Cadilac White Diamond for paint and it will have ghost blue pearl flames, with burgandy pearl highlights. Then on the sides where the windows would be if it was a suburban, I am going to have my logo with "ClassicHeartbeat" in (candy) ruby red, with the divider line, and "Pickup Parts" in Gloss Black, base coat clear coat. I also want the lettering to appear pushed into the paint and not just applied on top. The interior is actualy going to be from a couple of different vehicles. The color will be grey and I have a set of full electric, air lumbar, high back, bucket seats out os a 98 Explorer... The center console will be out of a mid 90s Firebird modified to fit. The carpet will be Black and the ware strips off of the floor will be removed then replaced with pollished stainless steel ones, aplied on top of the carpet. Oh and of coarse front and rear air!! WES www.ClassicHeartbeat.com
looking really good there WES !!!! :D
Thanks Kevin. I am working on installing the new A-arm brackets, front drop spindles, 2" front lowering springs, all new tie rods, ball joints, idler arm, and adjuster sleeves now. The front end will be all new and powder coated when I get done. WES www.ClassicHeartbeat.com
