Primary Power busbar for upgrades
So I am currently doing upgrades to my 72 C10, with a Holley Terminator Fuel Injection is first, then electric fans and Vintage air to follow. I believe these will all require a direct primary power feed. The pick up already has headlight wiring upgrade that has a direct feed from battery. If I have this correct I need a minimum of 4 primary feed sources, and was thinking of using the Bussmann LMI series, https://www.eaton.com/Eaton/Products...ries/index.htm to try and keep as tidy and effective as possible.
I am not very versed in auto electrics, so wondering if I am on the right track? Is there a better solution. How best to handle relays? Are there other items that will benefit from a direct power source, eg: fuel pump (Boyd Welding Aeromotive Stealth 340 In-Tank pump). thanks Roger |
Re: Primary Power busbar for upgrades
This is my usual recommendation. This comes out of a 90's era GM truck. GMT400 series? Around here $5~10 in a Pull-a-Part with the wires included. Advantage of this is the factory fusible links are already installed on the wires. The large coiled red wire is the alternator feed. If you haven't already, a larger alternator is in your future if you go through with your planned electrical additions.
There similar new solutions like your Eaton product if you can't find a yard pull. Be sure to allow for fuses or fusible links to keep a small electrical problem from becoming a 'replace the truck due to fire' problem. |
Attachment 2071521 |
Nice looking truck. |
I went with this one. Fed it with 4 AWG from the Alt and connected it to the BAT with 4 AWG then connected everything to it. https://www.summitracing.com/parts/qdb-568102 -klb |
Nice ride you have sir! I just picked up one of the bus bars a few weeks ago out of the local yard. I didn't think about the wires. I cut them all off to make it easy to pull. Dang Now I need to go back and find another one!:chevy:
dead parrot do you know the rating on these . They are like a fuse but no markings on them except numbers . I have a bunch of them so would be nice to know
On my salvage finds, unless the use is obvious, like the alternator wire in the pic, I try to match the copper wire size to what the gizmo I am running power for recommends and then the OEM link should be the proper size. |
