Differential Gearing Question
I will be putting a crate SBC 350 4 bolt main into my truck...bolted to that will be a rebuilt Muncie M20 wide ratio 4 Speed. First gear is 2.56:1.
Because the truck originally came with an inline 6 cylinder engine, the rear end has 4.11 gears in it. I know the 4.11 has to go, so I am looking to replace the gears in the rear end and hope to get a happy medium between half-way decent take-off power and highway drivability. So here is my question: What gearing will give me the best drivability in town and on the Interstate? I am looking at 3.43, 3.23, and was also looking at 3.08. I have been told that 3.08 may make the truck too sluggish taking off from a stop in town. Either way I do not want to be 'that guy' who holds-up traffic in town or on the interstate. I would like to be able to do 70 - 75 mph without the truck screaming at high RPMs. Thoughts? |
Re: Differential Gearing Question
3.43 is a nice all around ratio without overdrive.
With overdrive I bump up to 3.73. K |
I drove my 71 chevelle with 3.31s and an m20 for a while, and it was OK. I won't go any numerically lower than 3.23. Another option if you want a 4 speed would be a 2.88 1st gear ratio super t10. You could run a 3.08 in the rear and first would be similar to the m20 and a 3.42 rear.
Just my .02 Good luck Here is a link with t10 ratios https://www.chevelles.com/threads/su...-ratios.23335/ |
You don't have to ditch the 4.10 before you do the swap. Swap it first, drive it some and see what you think. 29" tall tires and the 4.10 are pretty nice for 55 mph and down driving. Once you get some miles on the rig then think about how it performs vs. what you want.
I believe the M20 has 1.00 final gear. What size tires are you running? With a 29” tire in the rear and a 3.55 gear, you would be running around 2050 RPM @ 50mph. The 3.55 would be a happy median. I think you’ll have a dog on your hands with a 3.08 gear.
I swapped a 4:10 rear behind a 250-6, for a 350 SBC and 3:08 gears.
I did an entire rear end swap from a salvage yard because I know entirely zip about setting up lash. Just how fast do you plan on cruising through town? A 350 CI Small Block Chevy built with torque in mind won't be blocking traffic if you don't want it to. :rolleyes: |
...well you shouldn't be listening to the baloney I spew out on this forum anyway. :rolleyes: |
I did not see where you mentioned your Tire Size / Height. There are several calculators online similar to the one in the link below that can give you a ball park idea how any changes you make will effect the drivability.
https://www.summitracing.com/newsand...tio-calculator |
My tire size is a 235 75 15 @ 28.25" height. Figured out the RPMs @70 MPH will be approximately 2675 if using a 3.23 rear end gears.
I think I can live with that. |
Which crate 350 engine are you planning to run? I ask because the torque curve will be the determining factor.
My dad has the 290hp crate engine with a COMP Thumpr cam, mated to an M20 in his 56 BelAir. When he first installed it, he had a 9" rear with 3.00:1 gears. It was terribly sluggish, and would slip the clutch on inclines. He ended up installing 3.70 gears, which are perfect. Cruise rpms are tolerable at 70. Also, it only has 27" tires(255/50/17). Are you certain your current rear has 4.11 gears? I ask because I always thought my truck(originally a 250/3ott) had 4.11s, but were actually 3.73. I honestly wouldn't go any higher than 3.42. Remember that a manual transmission spins at a different rpm than automatics because the clutch is engaged directly. There's no torque converter to use up extra rpms. |
I know you stated you want to stay with your 4 speed, but if you are not driving the truck, beating on it a ton, you might look into the 833(?) 4 speed that 4th gear is overdrive, and leave the 410 gears.
You didn't say how much time you will be driving at highway speeds. |
The first gear may not be deep enough for the trans you have combined with your tire height.
I put a T10 with 3.23 gears in a car with 255/60r15's, and my first gear was close to yours. It was a bit hard to get it rolling compared to where it should of been. In my opinion. It originally had a 4 speed saginaw with roughly a 3.0 first gear. I would drive it with the 4.10's for a start, and then make changes. |
https://www.powertrainproducts.net/P...iABEgLCpfD_BwE |
I'd still try the 4:10 at first anyway just to see what you think. |
