Fitment question - C10 rotors on a C20 front end
I have a complete cross smember from a 74 C20, and I was wondering if there is any way to install the 5 or 6 lug C10 rotors on the C20 front end?
The only reason I would want to do this, is if I were to install a 3:08 rear end on my 63 C20. Pretty sure there are no C20 rear ends that are geared that high, so, if I wanted to do this it would require a rear end from a C10 or other vehicle. |
Re: Fitment question - C10 rotors on a C20 front end
At that point, you're probably better off going with a c10 front cross member. I don't know of a way to put the c10 rotors on the c20 spindles
Oh well... I guess I will stay with 8 lugs. Now I will need to find a T5 trans! |
A 73-87 c10 complete front crossmember should be found for $50 without much effort.
I would love to find one for $50! |
The x-members are interchangeable. The difference is in the arms & supporting pieces that attach. The upper a-arm shaft will require the correct shaft for the x-member (for the correct sizing).
I have a 1/2 ton x-member under my R30 dually. I simply used the C30 bracing & the C30 dually arms + steering parts. But.... The tire size makes a difference on final drive rpms. What size tires? 3.54 gearing might be possible on the HD 8-lug stuff & would be close to the desired 3.08 (which I feel would not be a good choice for a heavy truck). |
Upper arms are the same it is the ball joint that is different. The upper bj bolts in. Lower arm is different b'cuz of the hole for the 3/4t Ball Joint that presses in. And of course the spindle itself is different due to the wheel bearing size.
