Cranks on run and crank/gauge question
At it again, I pulled my old harness and putting in a new bp automotive harness, I was hooking up the starter and solenoid wires, now it cranks in the run and crank position. Has anyone else encountered this problem? I did have a issue with the neutral safety switch before. I havnt fully wired up the gauges and inside of my cab. This is kicking my butt.
Second question I just bought a autometer 7004 lcd gauge cluster, I was running autometer electric gauges before, are those sending units still the same? |
Re: Cranks on run and crank/gauge question
might check the wire connections for the switch sound your your switch on and crank are touching or connected wrong..
You might also check your wires on the plug to make sure they’re in the right place my headlight switch from them came miss wired
