1982 GMC 4x4 Diesel
5 Attachment(s)
1982 GMC K2500 diesel. Runs and drives. I drive it multiple times a week. Clean title in my name. 4x4 works good. No smog needed since it's a diesel. Has the 6.2L diesel and a TH400 transmission.
The following parts are new: Glow plugs (AC Delco 60G), head lights, door panels, door window weather stripping, dash cover, turn signal switch, fuel tank selector switch, and various other little bits. I also have a fuel pump for it but I haven't installed it. Truck has cruise control that works (just needs new vacuum lines since they are rotted out, but I have used the cruise control.) Tilt column, cargo lamp, power locks (needs new solenoids), sliding rear window. Has Warn manual locking hubs. The bad: has rust in usual areas. Floors are solid though. It's a little smoky on startup but goes away after 10-15 seconds. I've been told this is indicative of a leaky injector or two. I am asking $6000 OBO. Will entertain In-person offers only. I am in St Helena CA Posted via Mobile Device |
