Stretch a cab?
My thoughts are wandering. My biggest complaint with my truck is the lack of leg room for my 6'3" frame. Anyone ever stretch a cab? Not a quad cab but 6"? 8"? How would one accomplish this?
Re: Stretch a cab?
Where are you thinking of making it bigger? The doors or the rear portion of the cab?
Re: Stretch a cab?
Re: Stretch a cab?
i know on most of the AD trucks they stretch the door section
Re: Stretch a cab?
Re: Stretch a cab?
Re: Stretch a cab?
. You might find one similar in this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=358906 |
Re: Stretch a cab?
If the gas tank is located inside the cab, some have moved it to under the bed to gain a few additional inches of leg room. Don't know if they moved the seat mount back, too, once the tank was out.
Re: Stretch a cab?
Here is a link to a Thread,
Member was going to go look at one to buy. It's a Little more than 6 to 8":ito: Link:https://67-72chevytrucks.com/vboard/...hlight=ext-cab Might give you some idea's:chevy: . |
Re: Stretch a cab?
Re: Stretch a cab?
If you you remove the tank you really don't gain any LEG room ,the top of seat usually hits the top of cab above tank first. I did the tank conv. on my 69 and never gained an inch of leg room extra storage space is nice though.
Re: Stretch a cab?
Removing the tank doesn't really accomplish much if legroom is the concern unless you recess the seating into the inner cab sheet-metal. Problem w/that will be your noggin gets real close to that back wall/glass @ that point.
Options are moving the pedals/flooring forward or stretching the cab length the amount desired (or a combo of the two). This was something I wanted to do on my 67/68 project & a contributing reason it got moth-balled. |
Re: Stretch a cab?
2 Attachment(s)
Here's one for sale:
https://www.facebook.com/marketplace...ok_story_share |
