Backyard built 55
Hey guys just thought I would post up my on going 55 build. I've been working on it daylight to dark for the last 2 months. There's alot of things I will change later right now I'm just trying to get it ready for the c10s in the park in September not sure if I'll make it, but we will see. I am also not a paint and body guy but I give it my best shot.. I'll try and post everything in order from start to where I am now.
Re: Backyard built 55
This is the subfrane I bought for the swap best I can tell its a 1975 camaro
2 Attachment(s)
Looks like junk but I got it where it needs to be
4 Attachment(s)
Started grinding the frame to try and clean it up but found a local guy that did mobile blasting so I had him come clean the subframe.
5 Attachment(s)
After I started assembly on the subframe it was time to move to the body. I know I know everyone hates fake patina well I like it I wasnt in love with how it looked before but the more I spray and sand the more I'm liking the look, which is good considering it's mine.
5 Attachment(s)
I started preparing myself to cut the from half of my original frame off. Not gonna lie I read every forum and watch tons of videos before I started ots a little intimidating but wasn't really hard. Fighting the rusted bolts and original rivets was the hardest part. My wheels also came in, who's not gonna throw one up under there just to see how it looks.
5 Attachment(s)
It's been raining and raining and raining with the ground so soft I didn't want to mess with the frame so I jumped in the cab. It left alot to be desired haha. Worked in sections doing one part at a time until I got everything sanded primed and painted. I lost most of my interior progress pictures do to breaking my phone.
Coming along nicely, keep at it and you’ll be driving it in no time .
Git Er Done !
2 Attachment(s)
Got the interior painted and the floors coated also picked out the seat design quoted from my local interior guy. 650 for vynil or 1200 for leather. What do you guys think is leather worth double the price?
Given that choice I would pick leather without hesitation.
3 Attachment(s)
With the interior painted I moved onto tacking in the frame under the truck with the sheet metal installed. I used the template everyone uses and mine was a little far forward so I trimmed another inch off of it and it looks alot better to me.
5 Attachment(s)
With the subframe all welded I removed the cab to have the rest of the frame blasted. While I waited I moved onto the firewall, again I'm not a painter I use a cheap gun and pre mixed paint. Once I got everything removed and sanded I laid down some black epoxy primer over the bare metal, then laid down my black then the red. Oh yeah and thank God I have a front end loader.
Looks great...Your moving right along. I really like those wheels.
Keep it up Marc |
contrast for the win, that red really stands out. love it.
I can stare at this all day! Does it come in Poster Size? and how long did that take to grind so nice, LOL ha ha
https://67-72chevytrucks.com/vboard/...1&d=1622475224 |
Yeah, I thought they looked like late model Camaro rims but I was not 100% certain..
Marc |
That’s some nice tig welding sir.
4 Attachment(s)
Let me see where were we ? I think about the trip to Rogers, AR to you pull it slavage yard. I got an 8.8 rear axle out of a 2001 ford explorer limited disc brakes, limited slip, and 3.73 gear for 175 bucks. It took me and my dad about 35 min to remove I also took the drive shaft so that I can have a new one built to match my trans and rear end I watched alot of videos read alot of forums before I cut down my axle. I removed 2-7/8" from the driver side to center my pinion between the frame rails and so I could use another passenger side shaft.
i've had a lot of great luck narrowing 9" axle housings like that, drive shafts, and even narrowed an axle shafts like that with good results.
being able to use a stock short-side shaft to center the pinion is a huge win! |
also, your pipe weld porn makes me feel things.
:flag: |
