Stock suburban 25 gallon fuel tank dimension, specifically from the flange up?
Anyone have or can get me the fuel tank dimensions for a squarebody suburban 25 gallon fuel tank? Of more importance is the distance from the flange on the tank to the top of the tank; (The flange that presses against the frame rails when mounting).
I have found on Advance Auto Parts website the overall dimensions of some of the 25 gallon tanks they sell, but I really need the dimension from the mounting flange to the top of the tank or the top of the tank's fill neck. I have a 1984 C10 Suburban. I removed the 41 gallon tank to replace it with a 25 gallon tank (so that it didn't hang so low below the body). For some reason the 25 gal tank I bought from Advanced Auto has the tank filler neck sitting far to high, about 3 inches to high, it hits the floor and is higher than the filler neck. I've already sold off my 41 gal tank so I don't have the measurement from the mounting flange to the to of the tank and / or tank fill neck. |
Re: Stock suburban 25 gallon fuel tank dimension, specifically from the flange up?
Never mind.
I forgot that I cut out the xmember that the old fuel tank pressed up against because it was in the way of where the Porterbuilt c-notch was to go into. So I have added 2 pieces of angle iron between the frame rails where the new fuel tank will raise up against. Got it covered. |
