Differential
Hey guys, I have a 1967C 20 with an eaten full floater rear end. I love everything about the truck except for the mileage. Is there any way that I can switch the rear end to a higher ratio so I can get better gas mileage? Thanks in advance
Re: Differential
The best you can do is 4.10
There is some ultra rare 3.90 that was made years ago there pretty much unobtanium Run a a taller tire and or a over drive |
Re: Differential
Do you know what the gear ratio is? Is it a leaf or coil rear suspension?
Re: Differential
Re: Differential
It goes 50-55 then pretty high revs which for a 327 is somewhat acceptable. I think it’s 485 or some other camper or trailer haulyratio
Re: Differential
65 mph is pretty high revs
Re: Differential
Overdrives are $2300
Re: Differential
As it was stated above the best you can do for that rear axle is 4.10's. Standard gear ratio for these was 4.56- thats most likely what you have. If you want to confirm there are numbers stamped on a flat area of the third member above the pinion or you can pull the cover and count the gear teeth.
Besides an overdrive unit or 5-speed transmission is to swap the rear axle out and that would either require fabrication to make a 14-bolt (they can be found with 3.73's) work with your coil springs or trying to find a Dana 60 from a coil spring truck that would bolt in and having a different gear ratio ring and pinion installed to get the ratio you want. |
Re: Differential
Re: Differential
What are high revs? 327's are built to take high revs from the factory as all SBC's are. And by high revs I mean somewhere in the neighborhood of above 5k RPM's.
However... running at 3,500 RPM's will suck a bit of gas. Gary |
Re: Differential
Dana 60 coil spring rears are out there and big block trucks had 3.55 gears. You can get aftermarket 3.31 gears as well. As noted above, brackets can be purchased and installed by a competent welder to put a full float or semi float 14 bolt in the truck with all the gear choices those allow.
Re: Differential
Re: Differential
Thank you all for the excellent info.
I will look into these options! Greg |
