Weather seals and rubber 71 Suburban
Hi All,
My 71 is at paint right now and I'm doing my best to collect all the weather seals, door bumpers, and rubber for it. I'm hoping to be able to get most if not all to completely refresh the truck. I have yet to find a complete package so I've been piecing it together as I go. Below is my current list. I'm sure I'm missing a lot as there aren't many category items for Suburban. Would you please let me know if you see anything that I'm missing and point me in the right direction? :metal: Here is my current list: Brothers Trucks: DFSS03D 1967-72 CHEVY/GMC TRUCK DOOR WEATHERSEAL - SUBURBAN/ PANEL SUBURBAN 1 $58.99 SSW6772 1967-72 CHEVY/GMC SUBURBAN SIDE WINDOW SEALS REAR SIDE WINDOW PAIR 1 $311.99 SCDG072 1960-72 CHEVY/GMC SUBURBAN DOOR HINGE GROMMETS GROMMETS 1 $34.99 W172DLX 1971-72 CHEVY/GMC TRUCK WINDSHIELD SEAL - DELUXE 1 $36.99 VWW0072 1967-72 CHEVY/GMC TRUCK VENT WINDOW SEAL SET PAIR 1 $43.99 PSK72FS 1971-72 CHEVY/GMC TRUCK FLEETSIDE PAINT SEAL SET 1 $36.45 THank you! |
Re: Weather seals and rubber 71 Suburban
Woody |
Seals and other rubber replacement items (4) Hood, Side Bumpers #30-1821 (?) (8) Door, Jam Bumpers #BMP 033-4 (Precision) (2) Rear Side Windows (large stationary) seals #70-1265-81 (Steele Rubber Products) (1) Rear Hatch Lower Seal #38-6205 (Precision) (1) Rear Hatch Upper Seal #38-6204 (67-704230 Counterpart Automotive) (1) Rear Hatch Glass Weatherstrip with Lock Bead #01-319 (?) (2) Rear Hatch Hinge Grommet #7034 (?) (4) Tailgate Rubber Bumpers #11-395 (Steele Rubber Products) (2) Stationary Door Glass Seals #38-6200 (Precision) (1) Vent Window Weatherstrip Set and Repair Kit #VWK111067 (Precision) (1) Windshield Weatherstrip (for use with SS trim) #49-8075 (Precision) (1) RH Rear Door Seal #38-6201 (Precision) (1) RH Front Door Seal #38-6199 (? G3005) (1) LH Front Door Seal #38-6198 (? G3004) (2) Front Door Window Seals #49-8762 (Precision…part of GMC Paul’s 8 pc kit #WFK111367) (2) Rear Door Window Seals #49-8763 (Precision…part of GMC Paul’s 8 pc kit #WFK112167) (1) Front Window Anti-Rattle 4 pc kit #WFK????67C (Precision…part of GMC Paul’s kit #WFK111367) (1) Rear Window Anti-Rattle 4 pc kit #WFK112067C (Precision…part of GMC Paul’s kit #WFK112167) (2) Front Window Division Bar Felt #111160 (Precision…part of GMC Paul’s kit #WFK111367) (2) Rear Window Division Bar Felt #111160 (Precision…part of GMC Paul’s kit #WFK112167) (4) Door Glass Stop Bumpers #AU-4280 (?) (2) Red Tail Light Lens #67-13450-SB (Counterpart Automotive) (2) Tail Light Lens Gasket #67-13460-F (Counterpart Automotive) (2) Clear Backup Lens #EF-2484 (TriPlus Automotive) (2) Backup Lens Gasket #ST-292 (?) (2) Backup Housing Gasket #ST-293 (?) (4) Side Marker Lamp Lens Gaskets #51-511 (?) (2) Kick Panel Door Vent Seal #411-67 (?) (1) Firewall Clutch Rod Cover Plate with Gasket #67-7515 (Counterpart Automotive) (2) Fuse Block Firewall Gasket #ST-250 (?) (1) A/C Inlet/Outlet Grommet #10-005 (?) (1) Wiper Motor Rubber Seal #10-018 (?) (1) Grommet/Retainer Kit #GMCP/CHBGK (?)... Kit includes: 1-windshield washer 3 hole grommet, 2-windshield washer hose single hose grommets, 1-oil pressure line grommet, 1-speedometer cable grommet, 1-emergency brake cable grommet, and 7-rubber firewall insulation pad retainers (1) Steering Column to Dash Seal #67-3513 (Counterpart Automotive) (1) Steering Column to Firewall Seal #76-35194 (Counterpart Automotive) (1) Power Booster Boot Seal #MBM7 (?) (1) Master Cylinder Boot Seal #10-010 (?) (1) Gas Tank Filler Neck Grommet #19723976 (?) (35) Plastic Interior Plugs #11749 (?) I tried to include who the manufacturer is (as that makes a difference to a lot of people), but that wasn't always available on some items, so I inserted (?). Most all of this came from GMC Paul's...but I found some pieces they didn't have by searching the internet once I figured out what the piece was actually called! Woody |
Paul |
I have heard that the 35 round Plastic Interior Plugs #11749 are no longer available. And the oval ones on the door pillar have not been available since the GM stock ran out decades ago. Be very careful if you have to remove any of them.
I sourced replacement body mount bushings from Classic Heartbeat for my Burban. You might enjoy looking at the first 5 or so pages of the WMB thread below where I posted some of the trials and tribulations I experienced with mine during the paint part of the project. |
Woody |
Woody |
2 Attachment(s)
I did the same total rubber replacement on my 71 (barn door). The only suprise i got was with barn door hinge seals.For some reason when the doors were installed there was not enough room between the hinge bracket and the body. Not sure if that was because the aftermarket parts are thicker than original part. If I would have discovered this before paint I could have widened the hinge clearance passage hole. The other mistake was not installing the gasket onto the hinge arm before shimming and fitment of the door. It is a pain to remove hinge and correct the error now so I had to split the gasket to fit it.
I will probably cut the lip from the rubber seal and attach it with good quality sealant. Our burb never sees rain so seal is not a big issue Hope this helps. |
I am pretty sure the lift gate and barn door hinge seals are the same. I too was not satisfied with the fit of them compared to the original factory seals. If I could go back I would reuse the originals.
