Using van hydroboost - will van master cylinder work?
Is anyone using the master cylinder off their hydroboost donor vehicle? This came off a 2009 express 3500 van. If so... The van did not have a proportioning valve. Do still need to run one on the C10? Photo of van's master cylinder is attached
Re: Using van hydroboost - will van master cylinder work?
I would say yes.
The van is a full bodied vehicle and is going to gave a lot more weight over the rear wheels than a pickup does. I would suggest an adjustable prop valve, so that you can tune what it really wants, rather than trying to match an off the shelf replacement. K |
Hope that helps. |
Mine did.
Discs front and rear? Or drums? The master cylinder will have a residual check valve for drums. |
I ask because from my research the newer (07ish and up) GM hydroboosters havr a different bore where the master cyl attaches |
