94 Blazer K1500 T.B.I. 5.7 stalling issue
1994 K1500 Blazer, 5.7 T.B.I.,Auto. im att the end of my witts with this truck. It starts, idles, but if you give it any fuel, it stalls, if you put it in gear, it stalls. new dist., coil pack, ICM, fuel injectors, fuel filter, etc. I'm at my witts end and but ready to sell it and make it someone else's problem, but, its my 4WD, and up till now, has been my daily driver for the past 5 years. ant suggestions?
Re: 94 Blazer K1500 T.B.I. 5.7 stalling issue
Throttle position sensor?
TPS could be it but you'll need a scan tool to see the voltage. Your best bet is to get a scan tool that you can see the data the ECM is seeing. Something is not sending the correct data to the ECM. If all the electronic stuff checks out, your EGR valve may have failed: http://67-72chevytrucks.com/vboard/s...d.php?t=549711 |
You can use a regular voltmeter to check the TPS voltage, you just have to probe the wires. Did you check for codes?
