difficult to get into park
Greetings,
I have a 72 c10 with turbo 350. The problem I am having is that it is tuff to put into park. Fiddle with the selector, pull towards you and it will go into park with significant force. Before I crawl under it, where should I look for the problem? thanks. |
Re: difficult to get into park
Check the pin in the selector lever. Those tend to slide out and cause problems.
Some people have had this problem from old and dryed out grease in the steering column collar. There have been some write ups about how to clean and lube the inside of the steering column.
Before you spend a lot of time trying to figure it out, try spraying some PB Blaster or other GOOD penetrating oil into the opening around the shift lever, where it goes into the column. Be sure it is in Neutral and the wheels are blocked. Stick the nozzle into the small open areas around the lever and give it good spray. Then pull the lever back toward you and push it down toward the dash, Do this 3 or 4 times and see if it loosens up. The lever should move up and down a couple of inches. Spray the column at the bottom under the hood too. Let us know if that makes any difference. If you have a nice floor mat or carpet put a piece of plastic or other protection under the work area and under the full length of the interior column. LockDoc |
If LockDoc's solution helps but doesn’t cure the problem it may be that the lower bearing surface for the shifter (not the column) is rusted as mine was. I had to remove the column and replace the bearing ring the shifter mechanism rides inside of.
Thanks. Will try the pb blaster and go from there.
Sorry for the delay, was off buying a seat for my truck. |
