19.5 high clearance srw rims
Hey guys. Years ago I had a GMC 3500 Longhorn with 19.5 tubeless rims. I have sold the truck years ago (:waah:) to keep the bride happy.
I am in search of the same rims for my 67 C20 build. I know they were available on P30 step vans and optioned on some pickups of that era. Anyone know of a source for these in the Northeast? I have seen them on Ebay and Facebook Marketplace. I was hoping to find a set a little closer. Thanks in advance to all!! |
Re: 19.5 high clearance srw rims
Can't help you, but I like your style. Good luck, I wish you luck in your search
Thanks for the replies guys.
Here is exactly what I am looking for, only closer to home. Attachment 2152681 |
You may want to check the cost of tires before making that decision. One of my trucks has factory 19.5s and decent imports like kumho are pushing $400 a piece for a non highway tread. I know that there are some light duty tires making it to market now for the diesel truck crowd but last I checked they were pretty expensive also. My 5500 is averaging 20k miles a set and has had kumho, Hankook, and Goodyears on it and is due for set number 4 at 80k miles. This truck does wiegh 12k pounds empty. I want out from under the 19.5s but semi tires are my only option and wheel adapters are over a grand themselves and tires are around $600 each. The p30 rims are usually expensive when you can find them. Good luck.
I would not recommend using 19.5 trailer wheels. Might be worth checking in with members oem4me, yelmer, or 60-66. I’d say that about half the 19.5s I’ve ever seen in existence have been on their trucks. Very, very hard to find. I spent quite some time tracking down a hodge-podged set of five 17.5 wheels. Finding what you seek locally will severely limit your market, unless you get lucky. If you’re determined, I’d open up the aperture, accept shipping cost pain, and scour CL, eBay, and post a WTB on this forum. If anyone has them stashed, they are probably members here. I think you are more likely to find them on the 60-66 side of the house.
Not going to use trailer wheels. Looking for Kelsey-Hayes made rims GM used in the 1960s. Thanks for your insight about where to look. I will check around the forum to see what I can dig up.
I like the way they look. I'm keeping the 17s on my 68 with bias ply mudders on it keep the farm truck look since that's where it came from
Last word of advice, make sure they are the "60's type 19.5" with the more positive offset, the "late 50's type 19.5" had the "flatter" style wheels.
And to make things harder they also were available on Internationals, Dodges and Fords too. I got my 17.5's from a Dodge guy because the Dodge hubcaps didn't fit.
This website may be able to help. I know they are a long ways away but they might have an east coast connection or be able to help with IDing the Chevrolet versions. https://akhwheels.com/ Good luck. I love that look too. |
Would the late 40's and early 50's ford high clearance wheels have clips? The regular sized Ford wheels did. |
As far as I know, the Ford and Dodge rims would fit a Chevy, but not vice-versa. The inner hub diameter on the Fords and Dodges were larger than GMs allowing them to fit GM but not GMs to fit the Ford and Dodges. Bolt spacing remained the same between the big 3.
I have seen those versions, but they don't look like these: Attachment 2152682 |
2 Attachment(s)
Just a thought on possible option.I provided centers out of 17.5 wheels and had 17" wheels 8" wide made in Landenberg PA. This gives unlimited tire option. I had the wheels powder coated in Argent / Rally wheel silver.
Attachment 2152675 Attachment 2152676 |
Any luck finding these? I'm looking as well up here in Canada?
Todd |
[quote=duallyjams;9008660]Just a thought on possible option.I provided centers out of 17.5 wheels and had 17" wheels 8" wide made in Landenberg PA. This gives unlimited tire option. I had the wheels powder coated in Argent / Rally wheel silver.
Looks great, if there is a will, there is a way. Now why can't the industry figure this out? A fortune could be made if they reproduce the 17.5" center piece with rivited clips for a common 16" wheel ring. It would be a godsend for '48-'68 3/4 ton owners who want to run period correct hubcaps. |
