Swinging tire carrier
5 Attachment(s)
Swinging tire carrier has everything but the catch on the tailgate, there is also a spring for the release lever missing. The inner brackets are homemade using originals as an example. The curved one is drilled and taped, the other one will need the holes drilled. The bolt to hold the tire was bent by previous owner for shipping, the bracket to hold it in position was welded so I removed the weld to get the bolt out. 450 plus shipping, if you need more pictures let me know.
Re: Swinging tire carrier
Pics
I have a tailgate catch for it now, so should be a complete setup
I’m sure this is long gone! But I’m looking for one complete! Thanks
Here is the one I have now, I don't believe the bolt is correct.
Ttt
Hi Dwayne,
Do you have an extra tailgate bracket? I like this style in lieu of the version that mounts at two points. |
