Is This Part Reproduced?
Working on getting a complete heater setup together and started on the exterior box, fan, heater core. Using two complete systems (thanks again Boog) I’ve got about everything except the fan section here. Both rusted badly but in different areas. A quick internet search for a replacement didn’t come up with anything.
Does anyone know if this piece is available and where? |
Re: Is This Part Reproduced?
Your suggestion was actually my "out" on this one. The section in the better one can be cut out and that section on the bad one is actually good. A little surgery and I'd have something useable. |
I'm pretty sure it is not reproduced. Best bet would be to find someone to sell you a used heater box, or have them take off the part you need and send only that.
That is a pretty commonly rusted out part. |
I think I have what you are looking for, pm sent.
Dan |
AC truck?
I couldn't find that part on my A/C truck so I just fixed the one I had. The only hard part was the little bend or channel in it by the door.
67C10step,
I removed my heater box from my 67 cab. I can throw this heater box in the mail for you if you need. I’m going with a Vintage Air heater box in the cab to replace it. Roger |
Sounds good, let me know anytime.
