70 c10 short bed floor measurements
Can someone with a steel short bed floor get me some dimensions like the picture I uploaded please?
I have repop. Fleetside,Fleeting, sides |
Re: 70 c10 short bed floor measurements
Here is a picture of my 67 shortbed I show 14" from center of wheel well bolt hole to center of bolt hole for bracket. It looks like the other measurement is from that wheel well hole to end of bed and I show that to be 17 1/2"
I hope that helps mike |
Yes the bolt hole measurements help,but could you get me measurements of the sheet metal end to end, I guess my red lines showed as the hole center to center, but I needed the metal dimensions.
Thank you for your help,very much appreciated. Phil |
I have a 67 short bed floor out of the truck in good shape. I'll get some measurements over to you.
3 Attachment(s)
Posted via Mobile Device |
Gentlemen thank you for all your help.
I'll post pics of the floor when I'm done. Phil |
2 Attachment(s)
Got the pieces welded in last night, needs some more grinding with an air mini grinder and my harbor freight mini hand held da.
I was not able to get the 18 1/4 and 15 1/4 numbers. Only 18 and 15 with the aftermarket besides frome classic industries. I did get the 14 inch hole dimensions though. I need to have someone blast the floor or I might get one of those cheap wet blasters you put sand in. |
