K10 front axle bump stops
This should probably be about the least of my worries, but it's been eating at me for a while. When I was cleaning up the front frame of my '68 K10 a while back I ended up pulling both of the bump stops out. One was already destroyed, and I did the second one in while removing it.
I haven't been able to find any replacements for these things anywhere. Are they just not made anymore? I've found some that look kind of close, but I think they are only listed for the back end of 2WD trucks so not sure if they would work. Plan B is to switch to the newer stud mounted ones that seem to be widely available. I figured I would ask here first in case I'm just not looking in right places... |
Re: K10 front axle bump stops
The rears look the same to me. I believe the bolt in style is listed for front and rear of a k10. If I were in your situation I would order the rear push in mounts from a place that allows returns and see if it fits. About $20 ea from what I have seen. If they do not work return them. Even with shipping back total loss will probably be around $30.
Thanks guys. I guess I won't be out too much to find out. Some of them have dimensions listed, and they all appear to be a good bit smaller than the ones I pulled out. They are probably cosmetic at this point anyway, since I put taller springs on it.
Edit: The MOOG K6607 is what I ordered. It looks to be a little taller than the others, and was available on Amazon of $15/pr. I'll try and remember to update this once I see how they fit. |
I know this is an older thread, but I just replaced two of these on my 1970 Blazer that did the same thing due to being 53 years old. NOS on Ebay is pretty easy to find.
https://i.ebayimg.com/images/g/Jf0AA...BZ/s-l1600.jpg GM part number 3843849. Fits 1963-70 trucks |
